Hiya, just been looking at classicswede store and there are "motorsport brackets" it say you gain a bit extra clearance for turbo conversions, would a garret t3 clear with these brackets?
Re: classicswede
I havn't used them, but have used a similar idea. It basically converts to a traditional mount the engine sits on, rather than hangs from that the 360 has. These clear lots of space for a turbo and the oil drain, but for a really big turbo to clear the chassis you may need an adaptor or custom manifold.
Re: classicswede
The T3 will just about clear but you will probably need to pack the drivers side mount with a couple of washers to gain clearance. The chassis rail is the big limiting factor
Re: classicswede
Thanks Dai, don't know when I will get around to my conversion but I will buy a set when I doclassicswede wrote:The T3 will just about clear but you will probably need to pack the drivers side mount with a couple of washers to gain clearance. The chassis rail is the big limiting factor
