Template/measurements for rear wiper installation?
Fuse
Post by Fuse »
I would need a template for drilling the hole for the rear wiper. It's the later model wiper (MK3) where the wiper arm attatch directly on to the motor.
So if anyone has a template or accurate measurements I'd be happy. :P
Thanks
-Marko
Fuse
Post by Fuse »
Still would need those measurements. :D
Post by petefarrell360 »
We'll see what we can sort out if I get five minutes!
Fuse
Post by Fuse »
Any progress? :D
Are they not in the Blue leaflet section? (Not that I've looked, but I found out that the mk3 spoiler ones were after I'd fitted one...)
jarlidge
Post by jarlidge »
i think the wiper position is the same on the mk2-3, so you should be able to use the blue leaflets, measurements.
Fuse
Post by Fuse »
Problem is there are no measurements at the blue leaflet. :P It just says that use the template to drill the holes but the blue leaflet at the Technical section doesn't have that template with it. :P
I'd forgotten, and five minutes didn't materialise! I'll try and do it tomorrow night when I get in, it wasn't dry tonight, infact it was tipping it down!
Duvel78
Website Admin
Post by Duvel78 »
Fuse wrote:Problem is there are no measurements at the blue leaflet. :P It just says that use the template to drill the holes but the blue leaflet at the Technical section doesn't have that template with it. :P
I can help you for this, I have found recently all the available blue leaflets for the 300 series, a very very good find in the Netherlands. I have the template. I will take a picture of it.
V3M for life!
Duvel78
Website Admin
Post by Duvel78 »
From the left of the boot to the center of the hole: 45,5 cm
From the bottom to the center of the hole: 10,7 cm
I hope this helps!
V3M for life!
